KB83190
Published: August 30, 2013
Project will not load if a link contains an invalid file path
OptoDataLink
Problem was discovered in version: R9.3c
Problem is fixed in version: R9.3d
When loading a project configuration file into OptoDataLink, if the source or the destination in a link is a file, and the file path is invalid, OptoDataLink will not load the project correctly.
If the symptom occurs when loading a project file into OptoDataLink, immediately exit OptoDataLink without saving or running the links. This will allow you to add the appropriate file paths on the computer or edit the project XML file with the correct path information.
To edit a project file with a known invalid path, simply open the .project xml file in a text editor and manually edit the file path.
