KB83223
Published: August 30, 2013
Manually deleting the project.grv file for groov Server causes a browser error
groov Server for Windows, including groov Software
Problem was discovered in version: R1.0c
If you delete the project.grv file in order to create a new project from a clean slate and then go to https://localhost/ in your browser, you may get an error that indicates, "You are not logged in," or you may get a dialog box that is stuck indicating "Loading pages."
Refresh the browser page.
