KB83255
Published: March 7, 2014
I/O is not enabled on redundant systems under certain conditions
Problem was discovered in version: R9.0a
Problem is fixed in version: R9.3e
If the controllers and arbiter on a redundant system are power cycled but the I/O is not, the controller may not be able to enable communication to the I/O, either using the PAC Control debugger or using strategy logic.
Shut down the entire system, including the I/O.
Turn the I/O on first.
Then turn on the redundant system.
