KB83259
Published: December 18, 2013
Error during setup process after groov is restored to default settings
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem was discovered in version: groov App R1.0c
Problem was discovered in version: groov Admin 1.570.25
When groov is restored to the default settings after a database has been created in groov with a user account, when you try to create a new account through the setup process, a dialog box may pop up with the message, "Cannot create the first account. Login as administrator to create a user."
Close the dialog box, and then open groov Build to create user accounts.
