KB83272
Published: March 7, 2014
Start Chart may fail when maximum number of charts are running
PACCONTROLBAS
PACCONTROLPRO
Problem was discovered in version: R9.0
When you attempt to start the maximum number of charts on a controller, the last chart may fail to start and you receive a -5 error (Operation Failed).
Reboot the controller.
Opto 22 has resolved this issue. The problem described in this report is normal behavior.
