KB83280
Published: March 7, 2014
Digital Counter on B3000 / B3000-B is cleared whenever communication from PAC controller to brain is enabled
Problem was discovered in version: R9.2
Problem is fixed in version: R9.3e
If you have configured a digital counter, and communication from the SNAP PAC controller to the I/O unit is disabled and re-enabled for any reason, including non-error conditions, the counter is cleared.
Do not disable the I/O unit.
