KB83288
Published: September 20, 2017
groov: Image gadget doesn't display recent changes to image file
GROOV-AR1-BASE
GROOV-SVR-WIN-BASE
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Versions affected: groov App R1.0c through R3.0e
Problem is fixed in version: groov App R3.1a
If you change an existing image file, and then re-upload it to an Image gadget using the same (original) file name and folder, the changes aren't visible in groov Build.
After re-uploading the changed image:
  1. In groov Build, click File > Save All Changes.
  2. In your browser, click the refresh icon.
The changes will now be visible.
