KB83289
Published: December 13, 2013
PAC Display Configurator: Regenerate Scanner Tag command misses file rollover trigger
Problem was discovered in version: R9.3b
Problem is fixed in version: R9.3c
Two symptoms:
  • PAC Display Event Log shows an error if a controller IP address changes.
  • A PAC Display SuperTrend log or Historic log file does not roll over correctly.
When configuring Historic Logs and SuperTrend logs, you can choose to roll over to a new file based on a trigger. If you later choose a different control engine, the old scanner tag is not updated and these errors may occur.
