KB83292
Published: August 15, 2014
groov Admin keeps the default username when a login is created
Versions affected: 1.570.35 and earlier
Problem is fixed in version: 1.570.36
After creating a login in groov Admin the first time or after restoring Admin to the default settings, Admin shows that you are logged in as "user" (the default username).
In Admin, click Logout on the left side. Then use the new username and password that was created during the "Welcome to groov" setup process.
