KB83293
Published: December 19, 2013
Applying security updates in groov Admin prevents groov Admin from loading groov App updates or restoring to defaults
Version affected: groov Admin 1.570.23
Problem is fixed in version: groov Admin 1.570.31
groov App displays a message that asks for a valid license file, as follows:
"When searching for a valid license-file, one or more errors were encountered:
The license is not valid because it has been modified. Please install a new license from www.opto22.com.
Please locate and upload a valid license-file."
After you click the "Choose License" button and try to import the valid license file, the following the error appears:
"Error: The license is not valid because it has been modified. Please install a new license from www.opto22.com."
Opto 22 has resolved this issue. When installing the latest groov software, make sure to install groov Admin first and then install groov App.
