KB83303
Published: March 7, 2014
Controller may reset when performing SNTP sync
SNAP-PAC-R1-FM
SNAP-PAC-R2-FM
Problem was discovered in version: R9.2c
Problem is fixed in version: R9.3e
If a chart in your strategy executes a Convert Number to String command followed immediately by a Synchronize Clock SNTP command, and another chart at the same time calls a subroutine, the controller may reset.
Sync time to the PC instead of SNTP.
