KB83323
Published: March 7, 2014
Using On-Pulse or Off-Pulse as watchdog may fail
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R2-FM
SOFTPAC
Problem was discovered in version: R9.3a
Problem is fixed in version: R9.3e
Some customers use the digital output On-Pulse or Off-Pulse as a watchdog, by continuously sending a new pulse instruction in a period that is slightly less than the pulse's length. However, if you do this, the digital point may still change states, making it appear a watchdog has occurred when it hasn't.
