KB83329
Published: March 14, 2014
I/O unit Watchdog, once enabled, won't disable
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R2-FM
SOFTPAC
Problem affects firmware versions: R9.3d and lower
Problem is fixed in version: R9.3e
If you enable an I/O unit's Watchdog feature in PAC Control's Configure mode and download and run the strategy, and then subsequently disable it by unchecking the Watchdog box (again in Config mode) and download and run the updated strategy, the unit's watchdog will continue to be enabled.
Clear the I/O unit's flash configuration, and then cycle power to the I/O unit.
