KB83346
Published: October 18, 2013
Opening FTP sessions in multiple charts may cause controller to reset
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R2-FM
Problem was discovered in version: R9.2a
Problem is fixed in version: R9.3e
When opening FTP sessions simultaneously from multiple charts, the controller host may stop communicating, or the controller may reset. If the controller stops responding on the host port, then any attempts to reconnect to the host port will result in error code -10038.
This affects the PAC Control Command Open Outgoing Communication (FTP communications handle only).
Perform FTP functions in only one chart at a time.
