KB83358
Published: November 17, 2020
Unable to Communicate from PAC Project Software on Windows 8, Windows 10, or Newer Computer to SNAP PAC Controllers
PACPROJECTBAS
PACPROJECTPRO
Problem was discovered in version: R9.3x
Problem is fixed in version: R9.4000
Loss of communication from PAC Project software on Windows 8, Windows 10, or newer computer to SNAP PAC controllers. Viewed in any PAC Project configuration window, a configured controller that appears normally as, for example, PacController is displayed as \\PacController\PacController after the problem occurs.
When you try to modify a controller, the network is locked into 255.255.255.255 and cannot be altered. An attempt to add a new controller results in the same corrupted name and network. No communication from an affected PC to a controller (including a SoftPAC local controller) will occur while this problem is experienced.
There are three possible workarounds.
Workaround #1:
- Try running the Windows compatibility troubleshooter on the PAC Project executable files Term.exe, Control.basic.exe and Control.pro.exe. Or manually configure these files to run in "Windows XP Spk3" compatibility mode.
- After running the Compatibility troubleshooter or manually changing the compatibility mode to Windows XP Spk 3, manually recreate the controller definitions using either PAC Term or PAC Control.
Workaround #2: Disconnect your Windows Microsoft cloud-based account and switch the machine to use a PC local account (Desktop Configuration Tool Icon > Change PC Configuration > Users > Your account).
Workaround #3:
- Exit PAC Control.
- Right-click the icon for PAC Control and choose the “run as admin” option.
- Add the control engine again.
