KB83360
Published: September 9, 2014
SoftPAC Monitor does not auto-display when configured to do so on Windows 8
SOFTPAC
PACPROJECTPRO
Problem was discovered in version: R9.3d
Problem is fixed in version: R9.4a
SoftPAC Monitor running on a PC with Windows 8 won't auto-display upon system start-up unless user account control (UAC) on the PC is at its lowest setting.
Set the host PC's UAC for administrative access. If that is not possible, SoftPAC Monitor must be started manually.
