KB83448
Published: June 4, 2014
After creating or uploading groov SSL certificates, back button leads to broken pages
Problem affects versions: groov Admin R1.570.34 and lower
In groov Admin, after you create a new SSL certificate for groov or upload an existing certificate, the page shows a back button at the bottom of the page that should take you back to the groov Admin configuration page. The back button does not take you there and instead shows a broken page icon or a notification that content was blocked.
Click the browser's refresh button or press F5 to refresh the page, and then accept the certificate security warnings again.
