KB83470
Published: June 4, 2014
groov gadgets cannot immediately write values after connection to a PAC has been lost and restored
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: R2.3c and lower
Problem is fixed in version: R3.0a
You may see an "unexpected error" or "Error: The value could not be written."
This issue may occur if groov's connection to an Opto 22 SNAP PAC controller has been lost and then restored. Gadgets cannot immediately write values again.
This issue does not affect OPC tags.
Wait a few seconds and try to write the value again. It usually clears after a time or two.
