KB83517
Published: October 16, 2014
groov View for iOS crashes when dismissing 'Unable to connect' dialog box
groov View for iOS
R2.1a
R2.1b
If you attempt to connect to a server that doesn't respond (for example, if you enter a bad URL) and then swipe back to the server list before the connection times out, attempting to dismiss the "Unable to connect" dialog box that appears will crash the app.
