KB83536
Published: October 7, 2015
In groov Build, changing users causes a stuck "loading tags..." dialog box
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: groov App R2.0a-2.0b
Problem is fixed in version: groov App R2.0c
In groov Build, if you choose Security in the menu bar, click "log out <username>," and then log back in with another account, a "loading tags..." dialog box appears and never seems to finish.
Press the ESC key to dismiss the dialog box.
