KB83563
Published: August 29, 2014
Applications using the OptoOPCServer erroneously report "Bad Quality" when no tag data or system failure has occurred
OptoOPCServer
Versions affected: R5.0 through R9.3a
Problem is fixed in version: R9.3b
Applications using the OptoOPCServer (such as PAC Display or an OPC
Client) may prematurely report "Bad Quality" even when no apparent tag
data or system failure has occurred.
This issue only occurs in very large systems with many charts running, lots of tags requested by the OPC Client, and large volumes of serial I/O. The internal timeout value used by the OptoOPCServer may not always be long enough for a massive system implementation.
