KB83595
Published: March 17, 2014
Modbus/TCP unsupported function codes return erroneous packets
SNAP-PAC-EB1
SNAP-PAC-EB1-FM
SNAP-PAC-EB1-W
SNAP-PAC-EB2
SNAP-PAC-EB2-FM
SNAP-PAC-EB2-W
G4D32EB2
G4D32EB2-UPG
OPTOEMU-SNR-3V
OPTOEMU-SNR-DR1
OPTOEMU-SNR-DR2
SNAP-PAC-R1-FM
SNAP-PAC-R2-FM
SNAP-PAC-S1-FM
Problem affects firmware versions: R9.3c and lower
Problem is fixed in firmware version: R9.3e
When an unsupported Modbus/TCP function code is sent to a SNAP PAC brain or controller, it
responds with an invalid response rather than the expected Modbus/TCP Invalid Function Error. If the invalid command
is the first to be sent to the brain or controller, it will respond with zeros.
If another command has been sent before the invalid command, the response will reflect the last valid
command.
The only workaround is not to send an unsupported Modbus/TCP command.
