KB83600
Published: February 17, 2022
PAC Control error -139 when opening strategy from a previous version
PAC Control Basic
PAC Control Professional
R10.4a
R10.4b
In PAC Control R10.4a, when you open an older strategy that has a variable with a description longer than 127 characters, PAC Control displays the message "Invalid length for Variable description. Must be 1 to 127 characters. Code -139".
Prior to R10.4b, PAC Control did not prevent you from entering a description longer than 127 characters in the Add Variable dialog.
Open the strategy in an older version of PAC Control and edit any variable descriptions that are more than 127 characters. Save the strategy, then it can be opened in PAC Control R10.4a.
