KB83661
Published: June 2, 2014
Numeric keypad does not work in some text input boxes for groov gadget properties
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem affects versions: groov App R2.1a and lower
Problem is fixed in version: R2.2a
In groov Build, you can't use the numeric keypad to enter numbers into some gadget property fields, in particular the slider gadget, round gauge, horizontal gauge, level gauge, and range indicator. The video gadget's update period is also affected.
In some cases you can enter initial numbers, but if you press Backspace, you can no longer use the numeric keypad.
Use the number keys along the top of the main keyboard rather than using the numeric keypad.
