KB83667
Published: August 28, 2014
E1 and E2 brains: Some configured values not stored to flash
Problem affects versions: Firmware R1.1d and lower
Problem is fixed in version: R1.1e
If you set Modbus, PPP, or Streaming configurations on an E1 or E2 brain board and store the configuration to flash, then after a power cycle, the values after restart will not reflect those saved to flash.
This issue does not affect the following configurations, which are correctly stored to flash:
Status
Point Config
Network Security
Reconfigure the E1 or E2 with a configuration file ("otg" file) using PAC Manager after every power cycle.
