KB83680
Published: July 9, 2014
Entire multi-select group is de-selected in groov Build when you click outside a gadget boundary
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Versions affected: R2.1d and earlier
Problem is fixed in version: R2.2a
In groov Build, you can select multiple gadgets by pressing the ctrl key and clicking each gadget you want to include. If you accidentally miss a gadget and click on the background with the ctrl key pressed, all previously selected gadgets are de-selected.
The selected gadgets should remain selected. They should only be de-selected if the ctrl key isn't pressed when you click on the background.
