KB83710
Published: March 12, 2014
Reimporting a strategy in groov Build resets the controller's port to 1
groov View running on:
  • GROOV-AT1, GROOV-AT1-SNAP
  • GROOV-SVR-WIN, GROOV-SVR-WIN-SNAP
R2.1a
R2.1c
After you re-import a PAC Control strategy, gadgets in groov View fail to connect; they show a yellow triangle. Gadgets cannot connect to the controller because the controller's port in the groov project has been reset to 1.
Edit the controller's address and set the port to 22001.
