KB83720
Published: April 29, 2014
Update Strategy Succeeds Once For Each idb.txt
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem was discovered in version: R2.0c
When attempting to update the strategy associated with an Opto 22 Controller configured in groov Build, no tag updates are imported from the strategy idb.txt file and no update confirmation or error appears.
This problem occurs when more than one Update Strategy operation is performed using the same idb.txt file without closing and opening the Configure Devices and Tags dialog box. For example, this might occur when tags are being configured and multiple controllers use the same idb.txt file.
