KB83750
Published: April 24, 2014
Label text changes to all lowercase when performing a Replace Tag in PAC Display Configurator
Problem was discovered in version: R9.3c
Problem is fixed in version: R9.3d
Label text will change to all lowercase when using the Find and Replace dialog box to search for text with Everywhere selected. For example, if you search for the mixed-case string "aBcD", upon completion the text will be "abcd".
