KB83807
Published: April 30, 2014
B1 and B2 End-of-Life Migration Path
Any version
Opto 22 can no longer obtain essential parts to continue manufacturing B1 and B2 brain boards. They have therefore reached their end of life.
Drop-in replacement brain boards were developed several years ago:
- The E1 replaces the B1 for digital I/O.
- The E2 replaces the B2 for analog I/O.
Replacing a B1 with an E1- Turn off power to the rack.
- Remove serial communication wiring from the B1 and remove the brain board from the rack.
- Install the E1 on the rack and replace serial communication wiring exactly as you had it on the B1.
- Install jumpers on the E1 exactly as they were on the B1.
- Turn on power to the rack.
Most existing Optomux programs will run as before without requiring any changes.
Replacing a B2 with an E2- Turn off power to the rack.
- Remove the B2 brain board from the rack.
- Install the E2 on the rack.
- Install jumpers on the E2 exactly as they were on the B2.
Please note: if your program requires very fast boot-up times, you may see changes. For more information, read
KB83808.
New capabilities: E1 and E2 brain boards also offer new capabilities not included on the
B1 and B2: Ethernet networking in addition to serial, and additional
protocols besides Optomux. For complete information on new features, see
the
E1 and E2 Architecture and Migration Overview (form 1567).
