KB83821
Published: August 25, 2014
Long name passed to "Get Pointer From Name" can cause controller reset
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R2-FM
SOFTPAC
Problem affects versions: Firmware through R9.4a
Problem is fixed in version: R9.4b
If a name more than 50 characters long is passed to the Get Pointer From Name command, the controller may reset.
Before calling this command, verify that the string you are passing is 50 characters or less.
