KB83863
Published: May 21, 2014
19 Slow Red Blinks on SNAP-PAC-S2
SNAP-PAC-S1-FM
Problem affects versions: R8.2 and lower
If you download firmware R8.2 or lower to a SNAP PAC S-series controller with a microSD slot, the STAT LED shows 19 slow red blinks (serial port 2 failure code).
Use firmware version R8.3 or higher on a SNAP PAC S-series controller. To install new firmware:
- Using an Ethernet crossover cable, connect the computer you will use for updating firmware directly to the PAC's ENET1 network connector.
- Press the controller's Reset button and wait while the STAT LED turns solid green. Release the button as soon as the LED starts to blink (takes 2-5 seconds). The LED will rapidly blink red/green, indicating that the controller is in loader mode.
- Follow instructions in the PAC Manager User's Guide (form 1704) to Install Firmware via Failsafe Bootloader Mode.
