KB83896
Published: December 2, 2015
OptoDataLink stops logging data if the scanner stops functioning
OptoDataLink
Versions affected: R9.3d and earlier
Problem is fixed in version: R9.4d
OptoDataLink, which uses the scanner from the OptoOPCServer, stops logging data if the scanner stops functioning or is manually stopped.
