KB83935
Published: July 3, 2014
"Error Opening Output File" response while attempting to update Firmware in SoftPAC
Version affected: R9.3d SoftPAC Monitor running on Windows 8.1 computer
Problem is fixed in version: PAC Project 9.4000
When attempting to update firmware while using SoftPAC Monitor R9.3d on a Winodws 8 computer, an error message is received stating that the firmware file can not be opened.
If this problem occurs, it is likely that the current installation of SoftPAC has become corrupted.
Follow these steps:
- Re-install SoftPAC.
- Manually launch SoftPAC Monitor it by right-clicking the icon used to launch Monitor and select Run as Administrator.
- In SoftPAC Monitor, click Update Firmware.
- In the Update Firmware dialog box, click Browse to locate the update file on your hard drive.
- Click Open and then Yes to install the update. A success message appears.
- Click Start SoftPAC unless it has already restarted.
- Download your strategy to the SoftPAC control engine and run it.
