KB83948
Published: November 3, 2014
groov View for iOS is missing Delete groov connection option on iPad
groov View for iOS
R2.32 and lower
R2.33
When you tap a groov connection on the iPad, you see Connect, Edit, and Set as Default. You should also see a Delete option so you can delete a groov connection.
