KB83952
Published: July 30, 2014
Grayed-out tags in the groov Build tag browser can be assigned to incorrect gadgets
GROOV-AR1
GROOV-AR1-SNAP
GROOV-SVR-WIN
GROOV-SVR-WIN-SNAP
Problem was introduced in version: R2.1a
Problem is fixed in version: R3.1a
In groov Build, when you choose a gadget and then assign a tag to it, tags that are inappropriate to use with that gadget are grayed out in the tag browser. For example, a tag with a Boolean data type is not suitable for a Round Gauge gadget; an input tag is not suitable for a Command Button gadget.
However, you can still choose a grayed out tag and assign it to an incorrect gadget.
Do not assign a grayed-out tag to a gadget.
