KB83972
Published: September 26, 2014
Storing SNAP PAC controller firmware to flash using microSD may fail
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R2-FM
Problem was discovered in version: R9.4a
Sometimes when you are trying to update firmware on a SNAP PAC controller from a microSD card, the firmware is not updated and stored to flash.
This issue affects firmware R9.4a only.
Try to update the firmware again. Perform another restore to factory defaults with the card inserted.
