KB83987
Published: August 25, 2014
Loading a strategy from microSD to controller flash memory may fail
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R2-FM
Problem affects firmware versions: R9.4a and lower
Problem is fixed in version: R9.4b
Trying to load a PAC Control strategy and firmware from a microSD card to flash memory on a SNAP PAC may fail. If you inspect the controller in PAC Terminal, you see "Stored in Flash: None" instead of "Stored in Flash: A strategy is stored in flash memory."
Hold the button to restore to factory defaults twice. The first time the firmware will be stored to flash; the second time the strategy will be stored.
