KB84017
Published: November 5, 2014
Invalid Memory Map Address error when using SoftPAC as a Generic MMP Device with a redundant controller
Problem affects versions: Firmware R9.4a and lower
Problem is fixed in version: R9.4b
When you try to use SoftPAC as a Generic MMP Device in a redundant strategy, you receive an invalid memory map address error in the redundant controller's message queue.
NOTE: SoftPAC itself cannot be used as a redundant controller. This issue occurs when a SNAP PAC S-series redundant controller attempts to read or write to SoftPAC as a generic MMP device.
