KB84077
Published: September 25, 2014
Opening an earlier PAC Display project in Runtime R9.4a may incorrectly show 'No Data Source Configured' message
Version affected: R9.4a
Opening an earlier PAC Display project in Runtime R9.4a may incorrectly show "No Data Source Configured" message. This issue can occur if the PAC Display project has either Operator Logging or SuperTrend Logging configured.
For Operator Logging: Configure the logging in Configure > Runtime > Security > Enable Runtime Operator Logging to specifically select a file for output rather than a data source.
For SuperTrend Logging: To save a SuperTrend log to a file, do the following:
  1. Choose the Select tool and double-click the SuperTrend.
  2. Click Log To, and then select Log File from the pop-up menu to display the Historic Log File Configuration dialog box.
For details, see form 1702, the PAC Display User's Guide.
