KB84084
Published: November 5, 2014
SNAP-AOV-27 initially outputs -10 VDC when I/O rack is powered up
SNAP-AOV-27
Problem affects: Modules manufactured Nov 2013 through Sept 2014
When an I/O unit with a SNAP-AOV-27 analog output module is first powered up, the module will output -10.0 VDC until the brain or rack-mounted controller finishes booting up. Then it will output the correct default voltage of 0.0 VDC until the brain or controller sets a new value.
If you have a SNAP-AOV-27 with this issue, contact Opto 22 Product Support for an RMA to return the module for a minor recalibration.
