KB84091
Published: October 13, 2014
When 'Exact Text' is selected on the Find and Replace Dialog Box in PAC Display Configurator, only the 'Everywhere' option is available
Version affected: R9.4a
If you select "Exact Text" on the Find and Replace dialog box, only the "Everywhere" option is available. You cannot select "Tags" or "Text on Window Objects." All three options ("Tags," "Text on Window Objects," and "Everywhere") should be available.
