KB84092
Published: November 5, 2014
Timeout error (-39) occasionally returned on SNAP PAC serial ports
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R2-FM
Problem affects versions: Firmware R9.4a
Problem is fixed in version: R9.4b
When you use serial communications on a SNAP PAC hardware controller for anything other than I/O, you may receive occasional timeout (-39) errors. This issue affects only the use of serial ports on SNAP PAC controllers; it does not affect TCP communication handles to serial modules on the rack.
Use the Send Communication Handle Command to send a "set.to:" command to set the timeout to an appropriate value.
