KB84110
Published: October 27, 2014
PAC Display Configurator View > TagInfoView does not work
Problem was introduced in version: R9.4a
Problem was introduced in version: R9.4c
After using View > Dynamic Attributes to generate a TagInfo4.txt file, if you try to open the file using View > Launch TagInfoView Utility, it may not be able to find the file, or PAC Display might crash, or it may result in an error such as "Only TagInfo2.txt files from OptoDisplay R4.1F and greater are supported."
