KB84133
Published: December 2, 2015
PID Auto/Man button in the PID Viewer does not always work
Problem was discovered in version: R9.4c
Problem is fixed in version: R9.4e
When using the PID Viewer in PAC Display Runtime (launched by clicking the PID button), the following problems can occur:
- If the Auto/Man button is configured to require a password, it will only work twice after entering the password; then it stops working.
- The Auto/Man button may stop working if pressed quickly a few times in a row.
- The state of the Auto/Man button may not be accurate if the PID loop auto/manual mode is changed outside of Runtime using PAC Control debugger or strategy logic.
