KB84134
Published: November 4, 2014
Serial communication module in rack position 15 may drop a packet
Versions affected: R9.4a and earlier
Problem is fixed in version: R9.4b
When the configuration for a serial communications module (SCM) at position 0 is sent to the module by the brain, if the module at position 15 is the same kind of SCM module, it triggers the brain to resend the configuration for SCM module 15 to SCM module 15. If the SCM module at position 15 is currently sending/receiving serial data when it gets reconfigured, it will drop that packet.
First configure all SCM modules before sending/receiving serial data.
