KB84135
Published: January 7, 2016
PAC Control: Unusual behavior when debugging string tables with non-printable ASCII characters
PAC Control Basic
PAC Control Professional
Issue affects: All versions
When inspecting string tables using the ASCII string view in PAC Control Debug mode, you may experience unusual behavior when the string table contains non-printable ASCII characters. Examples of non-printable ASCII characters include:
  • Null (NUL; HEX: 00)
  • Escape (ESC; HEX: 1B)
  • Cancel (CAN; HEX: 18)
Note that this issue is apparent only in the ASCII string view; the data appears normally when you use the Hex string view.
The following images demonstrate behaviors that have been reported.
Index 0 contains ABC~°± Null
Index 1 contains Null ABC~°
Index 2 contains A Escape B Null Cancel C
Index 3 contains ~°± Escape Cancel
Hex String View:
ASCII String View:
Note that any characters following the Null character become invisible in ASCII string view.
To view or edit string tables containing non-printable ASCII characters, use the Hex string view.
