KB84166
Published: November 10, 2014
PAC Control: Chart or host task using command Synchronize Clock SNTP may become unresponsive
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R2-FM
SOFTPAC
Problem affects versions: Firmware R9.4a
When using the PAC Control command Synchronize Clock SNTP, if the specified time server address can't be reached, the chart or host task may become unresponsive. Anything that prevents a connection to the specified time server, including a bad address, an unplugged cable, or an unresponsive server, may cause this issue.
A power cycle is required to recover.
Attempt to open a COM handle to the time server address. If the connection is opened successfully, close it and do the time sync; if the open fails, do not attempt the time sync.
