KB84174
Published: December 2, 2015
Non-text graphics rotated in PAC Display Runtime are not redrawn when opening an Always In Memory Window
Versions affected: R9.0a – R9.4c
Problem is fixed in version: R9.4e
When a non-text graphic such as a line or rectangle is rotated and its containing window has the Always In Memory checkbox checked, if the window is then closed and re-opened, the graphic is not displayed.
Select Window > Properties, then uncheck the "Always in memory" checkbox under Runtime Options.
