KB84196
Published: December 10, 2015
COM handle "get.srcport" command returns the source IP address instead of its port
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R2-FM
SOFTPAC
Problem affects versions: Firmware R9.4a and lower
If you're using a COM handle in PAC Control and send the "get.srcport" command, you receive the IP address of the host from which the controller received the last packet on the COM handle. For UDP, 0 may be returned. This command should return the source port.
